Ir para o conteúdo principal
Disassembling Chef's Choice M115 Case
O que você precisa
  1. Disassembling Chef's Choice M115 Case, Case: passo 1, imagem 1 %32 Disassembling Chef's Choice M115 Case, Case: passo 1, imagem 2 %32
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Disassembling Chef's Choice M115 Case: passo 2, imagem 1 %32
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Disassembling Chef's Choice M115 Case: passo 3, imagem 1 %32
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Disassembling Chef's Choice M115 Case: passo 4, imagem 1 %32
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
Conclusão
4 outras pessoas executaram este guia.
Zachary Grounds
Membro desde: 09/17/15
580 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-3, Harley Fall 2015 Membro de IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Membros
Autoria de 12 guias
Um comentário
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 41
Ao todo: 1,870
