Ir para o conteúdo principal
Casio Exilim EX-Z850 Outer Case Replacement
O que você precisa
  1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: passo 1, imagem 1 %32 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: passo 1, imagem 2 %32 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: passo 1, imagem 3 %32
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
  2. Casio Exilim EX-Z850 Outer Case Replacement: passo 2, imagem 1 %32 Casio Exilim EX-Z850 Outer Case Replacement: passo 2, imagem 2 %32 Casio Exilim EX-Z850 Outer Case Replacement: passo 2, imagem 3 %32
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
  3. Casio Exilim EX-Z850 Outer Case Replacement: passo 3, imagem 1 %32 Casio Exilim EX-Z850 Outer Case Replacement: passo 3, imagem 2 %32
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
Conclusão
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
Logan
Membro desde: 01/10/11
313 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-38, Regan Winter 2011 Membro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 3,036
