Ir para o conteúdo principal
Disassembling Casio CZ-1000 Backplate
O que você precisa
  1. Disassembling Casio CZ-1000 Backplate, Backplate: passo 1, imagem 1 %32 Disassembling Casio CZ-1000 Backplate, Backplate: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Disassembling Casio CZ-1000 Backplate: passo 2, imagem 1 %32 Disassembling Casio CZ-1000 Backplate: passo 2, imagem 2 %32 Disassembling Casio CZ-1000 Backplate: passo 2, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Disassembling Casio CZ-1000 Backplate: passo 3, imagem 1 %32 Disassembling Casio CZ-1000 Backplate: passo 3, imagem 2 %32 Disassembling Casio CZ-1000 Backplate: passo 3, imagem 3 %32
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
Conclusão
Jace Alexander
Membro desde: 10/24/24
181 Reputação
Autoria de 2 guias
Equipe
Cuesta, Team 60-3, Krynen Fall 2024 Membro de Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 143
