Introdução
This may need to be removed if the button or scroll wheel is not working.
O que você precisa
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove 2 screws from back of camera using screwdriver.
Remove 2 screws holding metal side guard using screwdriver.
Remove the connecting ribbon by pulling it straight out.
