Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
Unplug the green and white plugs that connect the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the tab at the back.
Remove 2 screws(1.75mm) using a screwdriver.
Detach 3 ribbons by pulling up on them. All are on the front of the camera.
Remove the newly exposed screw(1.75mm) with screwdriver.
Unhinge the black tab to slide out the ribbon.
The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
