Ir para o conteúdo principal
Disassembling Canon Powershot SD880 Logic Board
O que você precisa
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: passo 1, imagem 1 %32 Disassembling Canon Powershot SD880 Logic Board, Back Cover: passo 1, imagem 2 %32 Disassembling Canon Powershot SD880 Logic Board, Back Cover: passo 1, imagem 3 %32
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: passo 2, imagem 1 %32 Disassembling Canon Powershot SD880 Logic Board, Front Cover: passo 2, imagem 2 %32 Disassembling Canon Powershot SD880 Logic Board, Front Cover: passo 2, imagem 3 %32
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: passo 3, imagem 1 %32 Disassembling Canon Powershot SD880 Logic Board, Top Panel: passo 3, imagem 2 %32
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: passo 4, imagem 1 %32
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: passo 5, imagem 1 %32 Disassembling Canon Powershot SD880 Logic Board: passo 5, imagem 2 %32
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Conclusão
Juan Miguel
Membro desde: 01/13/11
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-3, Forte Winter 2011 Membro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 2,019
