Ir para o conteúdo principal
Disassembling Canon PowerShot SD800 IS Lens Assembly
O que você precisa
  1. Disassembling Canon PowerShot SD800 IS Lens Assembly, Back Cover: passo 1, imagem 1 %32
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 2, imagem 1 %32
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 3, imagem 1 %32
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 4, imagem 1 %32
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS Lens Assembly, Front Cover: passo 5, imagem 1 %32
    • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  6. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 6, imagem 1 %32
    • Remove one 2.25mm screw on the bottom of the camera.
  7. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 7, imagem 1 %32
    • Pull off the front cover.
  8. Disassembling Canon PowerShot SD800 IS Lens Assembly, LCD Assembly: passo 8, imagem 1 %32
    • Remove 2 2.4mm screws on bottom.
  9. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 9, imagem 1 %32
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  10. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 10, imagem 1 %32
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  11. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 11, imagem 1 %32
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
  12. Disassembling Canon PowerShot SD800 IS Lens Assembly, Flash Assembly: passo 12, imagem 1 %32
    • Remove one 3.9mm screw from inner frame.
    • NEW: Steps 8–11 (Removing the LCD Assembly) are unnecessary and can be skipped!!! Instead of the step shown here, you may access the Flash Assembly from the side of the camera—unscrewing it from the metal bracket that is attached to the inner frame. (The bracket will be clearly visible after removing the back and front covers—sorry, no photo!) Note that the Flash Assembly is also held to the bracket by 2 small posts along its plastic body; after unscrewing, pull the assembly gently away from the bracket to unseat the posts.
  13. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 13, imagem 1 %32
    • Follow the data cable to where it connects to the camera.
    • Lift up the back black portion to unlock the data cable.
  14. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 14, imagem 1 %32
    • Gently pull the red and black wires, lifting the white connector upwards, out of its position. (You may need to jiggle the wires from side to side somewhat to loosen the connector.)
    • Now that all cables and screws are disconnected, you can now remove the flash assembly.
    • To reinsert, line up connector with the copper leads on the camera, and gently press the white piece into place.
    • The black cable should be closer to the top of the camera.
  15. Disassembling Canon PowerShot SD800 IS Lens Assembly, Lens Assembly: passo 15, imagem 1 %32
    • Remove 5 3.1mm screws.
    • Remove 3 4.8mm screws.
  16. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 16, imagem 1 %32
    • Remove 1 3.0mm screw.
    • Remove 1 4.3mm screw.
  17. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 17, imagem 1 %32
    • Gently pull the red and black cables out.
    • The cables are attached to a white connector.
  18. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 18, imagem 1 %32
    • Remove 1 3.8mm screw.
  19. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 19, imagem 1 %32
    • Lift up the front black portion to unlock the data cable.
  20. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 20, imagem 1 %32
    • Gently pull the cable straight out.
    • This cable does not have a lock, unlike the others.
  21. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 21, imagem 1 %32
    • Disconnect cables.
  22. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 22, imagem 1 %32
    • Peel off the buttons on the back of the camera.
    • The button strip is attached by glue, so be gentle when pulling as not to rip the strip.
  23. Disassembling Canon PowerShot SD800 IS Lens Assembly: passo 23, imagem 1 %32
    • Pull off the rest of the button strip.
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy Rabaino
Membro desde: 10/10/10
135 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-9, Maness Fall 2010 Membro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 31
Duração total: 7,354
