Ir para o conteúdo principal
Introdução
Removing the back cover allows access to the LCD display and the flash assembly.
Peças
Nenhum componente especificado.
  1. Remove one 2.25mm screw on the bottom.
    • Remove one 2.25mm screw on the bottom.
  2. Remove two 2.25mm screws on the right side looking from the front.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Remove one 4.7mm screw on the side with the AV output.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Pull off the back cover.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
Conclusão
Jeremy Rabaino
Membro desde: 10/10/2010
135 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 20-9, Maness Fall 2010 Membro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Membros
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,517
