Introdução
This guide will instruct the user on how to remove the front cover of the Canon A590 IS.
O que você precisa
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
Press and hold down the button shown in the blue circle.
While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
5 outras pessoas executaram este guia.
3 comentários
A handy guide. I had an A590IS with a broken battery door latch on the camera body, and I managed to obtain a dead A590IS with a fully intact latch for free. So using this guide I swapped the body shells over! All fixed and working again!
Can the hatch be replaced. The piece that holds the hatch is broken.
alisonbforman46 - Responder
I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
Spud Head - Responder
