Introdução
This guide will show you how to disassemble the back and side panel of the printer.
O que você precisa
Lift up the back cover to remove it.
"quite a bit of force" is almost an understatement, I found 2 clips along the bottom of that rear piece, one at the far left one around the middle (indicated by an arrow on the underside of the machine) - undoing these required much persistence with a screwdriver
Thank you, Perhaps Fuzz. Thank you.
6 outras pessoas executaram este guia.
2 comentários
Good job!!!!
Where is the rest of disassembly?
