Ir para o conteúdo principal
Disassembling Canon Pixma MP480 Rear and Side Panel
O que você precisa
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: passo 1, imagem 1 %32 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: passo 1, imagem 2 %32
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 2, imagem 1 %32
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 3, imagem 1 %32
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 4, imagem 1 %32 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 4, imagem 2 %32
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 5, imagem 1 %32 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 5, imagem 2 %32
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 6, imagem 1 %32 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 6, imagem 2 %32
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 7, imagem 1 %32 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 7, imagem 2 %32
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: passo 8, imagem 1 %32 Disassembling Canon Pixma MP480 Rear and Side Panel: passo 8, imagem 2 %32
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Conclusão
6 outras pessoas executaram este guia.
Kevin Cole
Membro desde: 01/17/13
116 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 19-41, Regan Winter 2013 Membro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
Membros da 4
Autoria de 6 guias
2 comentários
Where is the rest of disassembly?
bill roberts - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 30
Duração total: 21,152
