Ir para o conteúdo principal
Disassembling Canon EOS Rebel XS Front Cover
O que você precisa
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: passo 1, imagem 1 %32
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: passo 2, imagem 1 %32
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: passo 3, imagem 1 %32
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: passo 4, imagem 1 %32
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
Conclusão
Daniel Bussone
Membro desde: 01/28/11
1.251 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 3-41, Regan Winter 2011 Membro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
Membros da 2
Autoria de 21 guias
2 comentários
This should be labelled: Easy.
tjt263 - Responder
Okay, there are several steps missing.
tjt263 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 5,261
