Ir para o conteúdo principal
Disassembling Canon EOS Rebel XS Battery Door
O que você precisa
  1. Disassembling Canon EOS Rebel XS Battery Door, Latch Side Cover: passo 1, imagem 1 %32
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Battery Door: passo 2, imagem 1 %32
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Battery Door, Disassembling Canon EOS Rebel XS Front Cover: passo 3, imagem 1 %32
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Battery Door: passo 4, imagem 1 %32
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Battery Door, Grip: passo 5, imagem 1 %32
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Disassembling Canon EOS Rebel XS Battery Door: passo 6, imagem 1 %32
    • Use your fingertip to pry off the external shutter port cover.
  7. Disassembling Canon EOS Rebel XS Battery Door: passo 7, imagem 1 %32
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Disassembling Canon EOS Rebel XS Battery Door: passo 8, imagem 1 %32 Disassembling Canon EOS Rebel XS Battery Door: passo 8, imagem 2 %32 Disassembling Canon EOS Rebel XS Battery Door: passo 8, imagem 3 %32
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Disassembling Canon EOS Rebel XS Battery Door: passo 9, imagem 1 %32
    • Once the grip is loose, use your fingers to remove it from the camera.
  10. Disassembling Canon EOS Rebel XS Battery Door, Battery Door: passo 10, imagem 1 %32
    • Remove the 4.8mm (.19in) long silver screw from the inside of the grip.
  11. Disassembling Canon EOS Rebel XS Battery Door: passo 11, imagem 1 %32 Disassembling Canon EOS Rebel XS Battery Door: passo 11, imagem 2 %32
    • Remove the hinge of the battery door from the inside of the grip.
    • Our sample camera's battery door was broken off of its hinge. Picture two shows an example of a battery door that is not broken.
Conclusão
Daniel Bussone
Membro desde: 01/28/11
1.251 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 3-41, Regan Winter 2011 Membro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
Membros da 2
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 4,987
