Ir para o conteúdo principal
Disassembling Breville BKC600XL Coffee Brewer Head
O que você precisa
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: passo 1, imagem 1 %32 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: passo 1, imagem 2 %32 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: passo 1, imagem 3 %32
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: passo 2, imagem 1 %32
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: passo 3, imagem 1 %32 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: passo 3, imagem 2 %32 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: passo 3, imagem 3 %32
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Conclusão
Uma outra pessoa concluiu este guia.
Antonio
Membro desde: 09/26/12
120 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 1-3, Propen Fall 2012 Membro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
Membros da 4
Autoria de 6 guias
2 comentários
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Responder
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 4,155
