Pular para o conteúdo principal
Introdução
This guide explains how to disassemble the Breville BKC600XL coffee brewer head.
Peças
Nenhum componente especificado.
  1. Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver. Reminder for reassembly; This bottom piece is first to be screwed back on. Reminder for reassembly; This bottom piece is first to be screwed back on.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Remove the grey plastic casing. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Conclusão
Antonio
Membro desde: 26-09-2012
81 reputação
6 Guias de autoria
Equipe
Cal Poly, Team 1-3, Propen Fall 2012 Membro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Membros
6 Guias de autoria
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Todo: 3,062
