Pular para o conteúdo principal
Introdução
The outer casing must be removed to replace any internal component of the Blackberry 8820.
To remove the outer casing of the Blackberry 8820, you must have a 1/16 inch diameter torx screwdriver ready as well as a plastic removing tool.
Peças
Nenhum componente especificado.
  1. Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. Remove the battery by prying under it with your finger or the plastic opening tool. Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  4. Use a nylon spudger to carefully remove the two side bars of plastic. Use a nylon spudger to carefully remove the two side bars of plastic.
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  5. Use a nylon spudger to carefully pry the back casing off.
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  6. Pry off the front casing.
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
Conclusão
Uma outra pessoa concluiu este guia.
ryan
Membro desde: 12-04-2013
41 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 13-64, Johann Spring 2013 Membro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membros
7 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 669
