Ir para o conteúdo principal
Disassembling Black and Decker BL3000S Blender Base
O que você precisa
  1. Disassembling Black and Decker BL3000S Blender Base, Blender Base: passo 1, imagem 1 %32 Disassembling Black and Decker BL3000S Blender Base, Blender Base: passo 1, imagem 2 %32
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Disassembling Black and Decker BL3000S Blender Base: passo 2, imagem 1 %32
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Disassembling Black and Decker BL3000S Blender Base: passo 3, imagem 1 %32 Disassembling Black and Decker BL3000S Blender Base: passo 3, imagem 2 %32
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Disassembling Black and Decker BL3000S Blender Base: passo 4, imagem 1 %32
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Disassembling Black and Decker BL3000S Blender Base: passo 5, imagem 1 %32
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew
Membro desde: 10/04/12
209 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-34, Regan Fall 2012 Membro de Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 28
Últimos 30 dias: 56
Duração total: 7,662
