Ir para o conteúdo principal
Disassembling Beaba Lutin night lamp
O que você precisa
  1. Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: passo 1, imagem 1 %32 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: passo 1, imagem 2 %32 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: passo 1, imagem 3 %32
    • The lamp opens up at the base: there are two smaller tabs next to the button, the semi-transparent plasic can be pressed in a bit with a knife, put a bit of paper inbetween to prevent the clip from snapping back. Next go with a knife towards one of the large tabs on the side until one side snaps out. Repeat for other side.
  2. Disassembling Beaba Lutin night lamp: passo 2, imagem 1 %32 Disassembling Beaba Lutin night lamp: passo 2, imagem 2 %32 Disassembling Beaba Lutin night lamp: passo 2, imagem 3 %32
    • Remove the 4 screws (warning: 2x2 different types), out comes the pcb. Detach battery connector at the back.
  3. Disassembling Beaba Lutin night lamp: passo 3, imagem 1 %32 Disassembling Beaba Lutin night lamp: passo 3, imagem 2 %32 Disassembling Beaba Lutin night lamp: passo 3, imagem 3 %32
    • remove two more screws to get at the battery
  4. Disassembling Beaba Lutin night lamp: passo 4, imagem 1 %32
    • Overview of parts
Conclusão
5 outras pessoas executaram este guia.
petur
Membro desde: 07/23/11
508 Reputação
Autoria de 3 guias
3 comentários
I think it is easier to open the lamp by pressing the semi-transparent part at the opposite side of the button.
Matthieu Morel - Responder
How can I open the lamp??? Please post a photo of how are u using the knife because I can't!!!
Alberto Santaella Gallego - Responder
you need to press the clips inward, the picture shows where the clips are. Slide inbetween and press
petur - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 11
Últimos 30 dias: 56
Duração total: 3,487
