Ir para o conteúdo principal
Disassembling Asus W2W-A1 Protective Cover
O que você precisa
  1. Disassembling Asus W2W-A1 Protective Cover, Keyboard: passo 1, imagem 1 %32 Disassembling Asus W2W-A1 Protective Cover, Keyboard: passo 1, imagem 2 %32 Disassembling Asus W2W-A1 Protective Cover, Keyboard: passo 1, imagem 3 %32
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Disassembling Asus W2W-A1 Protective Cover: passo 2, imagem 1 %32
    • Remove the panel above the keyboard with a plastic spudger.
  3. Disassembling Asus W2W-A1 Protective Cover: passo 3, imagem 1 %32
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Disassembling Asus W2W-A1 Protective Cover: passo 4, imagem 1 %32 Disassembling Asus W2W-A1 Protective Cover: passo 4, imagem 2 %32
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Disassembling Asus W2W-A1 Protective Cover, Front Panel: passo 5, imagem 1 %32
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
  6. Disassembling Asus W2W-A1 Protective Cover, Touchpad: passo 6, imagem 1 %32 Disassembling Asus W2W-A1 Protective Cover, Touchpad: passo 6, imagem 2 %32
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  7. Disassembling Asus W2W-A1 Protective Cover: passo 7, imagem 1 %32
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
  8. Disassembling Asus W2W-A1 Protective Cover, Protective Cover: passo 8, imagem 1 %32
    • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
    • Unscrew the 4 mm Phillips screw beneath the panel.
  9. Disassembling Asus W2W-A1 Protective Cover: passo 9, imagem 1 %32 Disassembling Asus W2W-A1 Protective Cover: passo 9, imagem 2 %32 Disassembling Asus W2W-A1 Protective Cover: passo 9, imagem 3 %32
    • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
    • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
    • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
    • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
    • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
    • Unscrew the 5mm Phillips head screw that lies just above the D screw.
  10. Disassembling Asus W2W-A1 Protective Cover: passo 10, imagem 1 %32
    • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
    • After finishing this step, flip the laptop over.
  11. Disassembling Asus W2W-A1 Protective Cover: passo 11, imagem 1 %32
    • Everything should now be loose enough for you to start removing the panel.
    • Do not fully remove the panel, for there are still ribbons attached on the inside.
  12. Disassembling Asus W2W-A1 Protective Cover: passo 12, imagem 1 %32
    • Carefully remove the ribbons from the base.
    • Then you can lift the panel to access the components beneath.
Conclusão
Nolan Schock
Membro desde: 04/14/14
501 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-29, Maness Spring 2014 Membro de Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 418
