Ir para o conteúdo principal
Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
O que você precisa
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: passo 1, imagem 1 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: passo 1, imagem 2 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: passo 1, imagem 3 %32
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 2, imagem 1 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 2, imagem 2 %32
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 3, imagem 1 %32
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 4, imagem 1 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 4, imagem 2 %32
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 5, imagem 1 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 5, imagem 2 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 5, imagem 3 %32
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 6, imagem 1 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 6, imagem 2 %32 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: passo 6, imagem 3 %32
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
Conclusão
Kue
Membro desde: 03/18/15
301 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-2, Lauer Spring 2015 Membro de Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 303
