Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Release the catch by pushing it in using a plastic opening tool.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
10 outras pessoas executaram este guia.
3 comentários
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
