Introdução
This guide shows you how to remove the cover of an Apple IIc computer. All you need to perform this repair is a screwdriver and something to help open the casing. This is a precursor to any other repair you may want to do on this device and also allows you to get a good look at its internal workings.
O que você precisa
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
10 outras pessoas concluíram este guia.
2 comentários
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
