Introdução
Removing the back panel of your Acer Iconia A1-830 tablet gives you access to its inner components. Double check the position of your plastic opening tool before applying force, to make sure it doesn't slip out.
O que você precisa
Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
Shut down your Acer Iconia A1-830.
Remove any cables or exterior covers from your tablet.
Place it on your work space, with the screen facing up.
10 outras pessoas executaram este guia.
2 comentários
Hi iv got an acer icon is one 10.iv done a factory reset ,but it hasent come back ,and it turns on but I can't stop it talking ,volume won't turn down and ,when I checked the volume button it says it turn off .the tablet won't do anything .can you tell me if it's worth repairing and how much if possible. Thank you Teresa spry
Can the back of the tablet be completely removed, so i can look at the micro USB port, to see if that is what is not letting the tablet charge !! Without not knowing what I’m doing and messing it up!!
