Introdução
This guide will show you how to disassemble the rear panel for a Asus MeMO Pad 7. This is the very first part to start to access all the parts on your tablet. You can remove the rear panel to check the parts and do the replacement guides of the tablet.
O que você precisa
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
8 outras pessoas executaram este guia.
