Ir para o conteúdo principal
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
O que você precisa
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: passo 1, imagem 1 %32 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: passo 1, imagem 2 %32
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 2, imagem 1 %32 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 2, imagem 2 %32 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 2, imagem 3 %32
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: passo 3, imagem 1 %32
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Conclusão
8 outras pessoas executaram este guia.
Efe Guldogan
Membro desde: 08/26/15
860 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 14-23, Meier Fall 2015 Membro de USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 32
Duração total: 13,609
