Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:Plastic Cards$2.99-
Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
Gently lift the mid-frame out of the case with your hands.
Now comes the hard part.
Your Kindle may not respond to the power button, and disconnecting the frontlight at this point will leave it in that unusable state.
Tap on or bring a magnet close to the hall effect sensor.
When the frontlight lights up, immediately unplug its connector.
If your Kindle remains awake for more than 3 seconds, you may now put it back to sleep by pressing the power button.
If not, you may have to repeat this step.
You will then need to cover pins 2 and 4 of the front light connector.
Cut a small piece of electrical tape that is thin enough to cover both pins, and apply it.
Reconnect the frontlight.
Uma outra pessoa concluiu este guia.
3 comentários
Brilliant! I just went through the process of disconnecting my hall sensor harness to fix an intermittent wake/lock issue. It worked, but i didn’t realize I’d nerfed the backlights until after getting it all reassembled. Thankfully found this guide and it worked perfectly.
Cover sensor was malfunctioning after a battery replacement so I followed your guide and it worked wonderfully! Hope to get another 8 years from this thing instead of dropping it in a landfill! Thanks
Very clever! Thank you. In the event, changing the battery on my 7th generation Kindle Paperwhite seems to have fixed the problem with the cover sensor. That triggered a hard reset, so it might be worth trying that before continuing with this mod.
