Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace the brush roller on your Dirt Devil Vibe vacuum when the brush on your vacuum stops spinning or spins too slowly. You will need a #0 phillips-head screwdriver to complete this replacement. Make sure the vacuum is unplugged before starting the replacement process for safety purposes. Make sure to keep track of all screws that will be removed during the replacement process.
O que você precisa
