Ir para o conteúdo principal
Dirt Devil Scorpion Quick Flip Filter Adapter Replacement
  1. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: passo 1, imagem 1 %32 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: passo 1, imagem 2 %32
    • First, press the button on the handle of the vacuum to separate the two halves.
    • The button triggers a release mechanism, detaching the front half from the back of the vacuum.
  2. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: passo 2, imagem 1 %32
    • Once the front half has been separated from the back half, locate the filter adapter.
    • The filter adapter is attached to the filter, locating the filter in this step will sufficiently locate the filter adapter.
    • Grasp the filter and adapter. Pull them out together.
  3. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: passo 3, imagem 1 %32 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: passo 3, imagem 2 %32
    • Rotate the filter counterclockwise to remove it from the filter adapter.
    • Once the filter adapter has been removed from the filter, replace it.
Conclusão
Joseph Warner
Membro desde: 11/11/17
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Wilson Fall 2017 Membro de IUPUI, Team S1-G1, Wilson Fall 2017
IUPUI-WILSON-F17S1G1
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 508
