Ir para o conteúdo principal
Direct-Drive Turntable Cartridge and Needle Replacement
O que você precisa
  1. Direct-Drive Turntable Cartridge and Needle Replacement, Cartridge and Needle: passo 1, imagem 1 %32
    • Check the needle and cartridge to see if they need to be replaced.
    • If the cartridge is touching your vinyl, it must be replaced.
    • Additionally, if you can hear scraping when playing the record, or if you see new scratch marks on the vinyl, it is time to change the cartridge and needle.
  2. Direct-Drive Turntable Cartridge and Needle Replacement: passo 2, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 2, imagem 2 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 2, imagem 3 %32
    • Manually unscrew the bulb on the tone arm from the headshell.
    • Pull out the headshell once it is completely unscrewed from the tone arm.
  3. Direct-Drive Turntable Cartridge and Needle Replacement: passo 3, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 3, imagem 2 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5 mm flathead screwdriver to remove both screws from the headshell.
  4. Direct-Drive Turntable Cartridge and Needle Replacement: passo 4, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 4, imagem 2 %32
    • Gently pull the four wires out from the back of the cartridge.
  5. Direct-Drive Turntable Cartridge and Needle Replacement: passo 5, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 5, imagem 2 %32
    • Pull the needle off of the new cartridge to ensure it does not get damaged during installation.
  6. Direct-Drive Turntable Cartridge and Needle Replacement: passo 6, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 6, imagem 2 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 6, imagem 3 %32
    • Connect the wires on the headshell to the new cartridge by matching the colors of the wires to the pins on the cartridge.
    • Place the headshell back onto the cartridge, being sure to line up the holes for the screws.
    • Place the screws back into the holes connecting the headshell and the new cartridge.
  7. Direct-Drive Turntable Cartridge and Needle Replacement: passo 7, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 7, imagem 2 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 7, imagem 3 %32
    • Screw the screws in using a 2.5 mm flathead screwdriver. Ensure the headshell is securely attached to the cartridge.
    • Slide the new needle back onto the cartridge.
  8. Direct-Drive Turntable Cartridge and Needle Replacement: passo 8, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 8, imagem 2 %32 Direct-Drive Turntable Cartridge and Needle Replacement: passo 8, imagem 3 %32
    • Attach the headshell to the tone arm and screw the headshell in from the tip of the tone arm.
    • Ensure that the headshell is secured in the tone arm and that there is no movement in the headshell when connected to the tone arm.
  9. Direct-Drive Turntable Cartridge and Needle Replacement: passo 9, imagem 1 %32
    • Place the needle onto a vinyl record and ensure that only the tip of the needle is touching the record and not the cartridge.
  10. Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: passo 10, imagem 1 %32 Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: passo 10, imagem 2 %32 Direct-Drive Turntable Cartridge and Needle Replacement, Check alignment of the needle: passo 10, imagem 3 %32
    • For good sound the needle has to fit parallel into the record groove. Othrewise the sound isn't leveled between left and right channel.
    • Therefore templates are available to buy or to print. They got orthogonal lines on the area where the needle is setting in and where it is setting off.
    • The needle should be parallel to the lines on the template at R120,9 mm. If not, the screws shown in step 3 can be loosened and the cartridge can be adjusted. After adjusting tight the screws up again.
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 1,290
