Ir para o conteúdo principal
Direct-Drive Cleaner Head Brush Bar Replacement
O que você precisa
  1. Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: passo 1, imagem 1 %32 Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: passo 1, imagem 2 %32
    • First, make sure the device is unplugged and detached from the wand
    • Use a quarter to unlock the fastener marked by padlocks, turning it counter clockwise
    • Padlocks
  2. Direct-Drive Cleaner Head Brush Bar Replacement: passo 2, imagem 1 %32
    • Slide the brush bar away from the cleaner head
Conclusão
6 outras pessoas executaram este guia.
Saba G Arefaine
Membro desde: 10/18/17
272 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G5, Rose Fall 2017 Membro de UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
Membros da 4
Autoria de 15 guias
2 comentários
While a clogged head was not the reason my Dyson V8 was stuttering, logic prompted me to check the big tube for an obstruction. My Dyson had a hairball as a result of picking up after my cat. Thank you!
John McCormick - Responder
My daughters Dyson V8 head is not powering the tube and rotating head. I have a Dyson V10 animal which I can attach to the V8 tube and rotating head and operates, so the problem is in the power head. I have cleaned the contacts and don’t know what else to do. Any suggestions?
Tom Murphy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 170
Duração total: 35,637
