Ir para o conteúdo principal
Digitech XC- 5206 Motherboard Replacement
O que você precisa
  1. Digitech XC- 5206 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Digitech XC- 5206 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off. You may need to use extra force.
  2. Digitech XC- 5206 Motherboard Replacement: passo 2, imagem 1 %32 Digitech XC- 5206 Motherboard Replacement: passo 2, imagem 2 %32 Digitech XC- 5206 Motherboard Replacement: passo 2, imagem 3 %32
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Motherboard Replacement: passo 3, imagem 1 %32 Digitech XC- 5206 Motherboard Replacement: passo 3, imagem 2 %32 Digitech XC- 5206 Motherboard Replacement: passo 3, imagem 3 %32
    • Cut zip-ties wrapped around red and green wires using scissors or pliers.
  4. Digitech XC- 5206 Motherboard Replacement: passo 4, imagem 1 %32 Digitech XC- 5206 Motherboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull wires out of ports using blunt nose tweezers.
  5. Digitech XC- 5206 Motherboard Replacement: passo 5, imagem 1 %32 Digitech XC- 5206 Motherboard Replacement: passo 5, imagem 2 %32
    • Unscrew two 10 mm screws below connecting motherboard to speaker system by spinning a Phillips PH2 bit screwdriver in a counterclockwise motion.
  6. Digitech XC- 5206 Motherboard Replacement: passo 6, imagem 1 %32
    • Pull motherboard out of slot using the angled tweezers and blunt nose tweezers on each side.
  7. Digitech XC- 5206 Motherboard Replacement: passo 7, imagem 1 %32 Digitech XC- 5206 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove motherboard from white wire strip by pulling the two apart using blunt nose tweezers on one side and fingers on wire strip plug.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 213
