Ir para o conteúdo principal
Digitech XC- 5206 Buttons Replacement
O que você precisa
  1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: passo 1, imagem 1 %32 Digitech XC- 5206 Buttons Replacement, Speaker Buttons: passo 1, imagem 2 %32
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Buttons Replacement: passo 2, imagem 1 %32 Digitech XC- 5206 Buttons Replacement: passo 2, imagem 2 %32 Digitech XC- 5206 Buttons Replacement: passo 2, imagem 3 %32
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Buttons Replacement: passo 3, imagem 1 %32
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  4. Digitech XC- 5206 Buttons Replacement: passo 4, imagem 1 %32 Digitech XC- 5206 Buttons Replacement: passo 4, imagem 2 %32 Digitech XC- 5206 Buttons Replacement: passo 4, imagem 3 %32
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 152
