Ir para o conteúdo principal
Digital2 Platinum Pad 9 Volume Buttons Replacement
O que você precisa
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: passo 1, imagem 1 %32
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 2, imagem 1 %32 Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 2, imagem 2 %32
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 3, imagem 1 %32 Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 3, imagem 2 %32
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: passo 4, imagem 1 %32
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 5, imagem 1 %32
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 6, imagem 1 %32
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 7, imagem 1 %32
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 8, imagem 1 %32 Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
Conclusão
David DeMeritt
Membro desde: 03/08/16
637 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 5-6, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 99
