Introdução
We are going to teach you how to remove the buttons of your Digital2 Platinum Pad 9. This is a very simple guide and easy to follow and complete. But you will need to be able to identify components, you can learn how to do that by following this guide Recognizing & Disconnecting Cable Connectors.
O que você precisa
Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
You can locate the volume buttons on one of the longer sides of the tablet.
