Ir para o conteúdo principal
Digital2 Platinum Pad 9 External Cover Replacement
O que você precisa
  1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: passo 1, imagem 1 %32
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Cover Replacement: passo 2, imagem 1 %32 Digital2 Platinum Pad 9 External Cover Replacement: passo 2, imagem 2 %32
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Cover Replacement: passo 3, imagem 1 %32 Digital2 Platinum Pad 9 External Cover Replacement: passo 3, imagem 2 %32
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
Conclusão
David DeMeritt
Membro desde: 03/08/16
637 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 5-6, Landers Spring 2016 Membro de UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 305
