Ir para o conteúdo principal
Digital2 D2-912 Screen Replacement
O que você precisa
  1. Digital2 D2-912 Screen Replacement, External Cover: passo 1, imagem 1 %32
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Screen Replacement: passo 2, imagem 1 %32 Digital2 D2-912 Screen Replacement: passo 2, imagem 2 %32
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Screen Replacement, Screen: passo 3, imagem 1 %32
    • Be sure to remove the yellow tape that is holding the components down.
    • Locate the two yellow ribbon cables and carefully remove by lifting the black tab connectors forward and slide out ribbon.
    • When all components are unsecured, you will be able to remove the battery, motherboard, camera, and speaker out of the way.
  4. Digital2 D2-912 Screen Replacement: passo 4, imagem 1 %32
    • Using the metal spudger, pry the display from the screen.
  5. Digital2 D2-912 Screen Replacement: passo 5, imagem 1 %32
    • The screen is now ready to be replaced by the new one
Conclusão
Equipe
IUPUI, Team 1-1, Harley Fall 2015 Membro de IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
Membros da 4
Autoria de 6 guias
3 comentários
Dear Lindsay,
thank you for the guide how to open up that little thing!
Apparently I have fried it after I had mislaid the charger and used my
universal charger without checking the voltage: 8 instead of 5... If only
I had used my reading glasses.
Is there something like a fuse that I could repair/exchange?
Thank you for your help!
Respectfully,
Wolfgang
Dr. Wolfgang Mohr - Responder
Thanks for the help, I am just curious where I can get the new screen, I believe that the front glass is fine but the actual display I am pretty sure is not.
Super Manny - Responder
This website right here. Straight trash,basically So you have a broken tablet. You come to the website to get help to replace it. And it's no help at all. This is what I think about this hot mass right here
Rocia Patrick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 619
