Ir para o conteúdo principal
Digital2 D2-912 Motherboard Replacement
O que você precisa
  1. Digital2 D2-912 Motherboard Replacement, External Cover: passo 1, imagem 1 %32
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Motherboard Replacement: passo 2, imagem 1 %32 Digital2 D2-912 Motherboard Replacement: passo 2, imagem 2 %32
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • Remove the wires shown in the image, using a soldering iron and solder sucker.
    • By removing the wires, you are detaching the battery and speaker from the motherboard.
  4. Digital2 D2-912 Motherboard Replacement: passo 4, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the three screws from motherboard.
  5. Digital2 D2-912 Motherboard Replacement: passo 5, imagem 1 %32 Digital2 D2-912 Motherboard Replacement: passo 5, imagem 2 %32
    • Detach the capacitive touch controller from the motherboard.
    • Carefully pry the narrow black connector upward to release the ribbon.
    • Remove the ribbon from the connector.
  6. Digital2 D2-912 Motherboard Replacement: passo 6, imagem 1 %32
    • Locate the camera found in the image.
    • Carefully pry the black connector upward to release ribbon.
    • Remove the black tape to release the camera from the motherboard.
    • Remove and replace the motherboard.
Conclusão
Jason Wignot
Membro desde: 09/16/15
322 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-1, Harley Fall 2015 Membro de IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 379
