Ir para o conteúdo principal
Digital Caliper Wrong Reading
O que você precisa
  1. Digital Caliper Wrong Reading, How to open the reading head: passo 1, imagem 1 %32
    • The reading changes all the time, there is some dust or dirt in the sensor.
  2. Digital Caliper Wrong Reading, The problem: passo 2, imagem 1 %32 Digital Caliper Wrong Reading, The problem: passo 2, imagem 2 %32
    • The problem is actually, how do you open it...
    • There is a very thick and well glued label on the back which hides the screws which need to be removed. Then it is easy.
    • When everything is disassembled, generally a cleaning of the surfaces is enough to make it work again.
    • Do not forget to readjust the screws tightening the sliding joint. Is is on the side.
Conclusão
Uma outra pessoa concluiu este guia.
Michal Ruzek
Membro desde: 01/27/22
739 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 58
Duração total: 887
