Ir para o conteúdo principal
Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement
O que você precisa
  1. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: passo 1, imagem 1 %32 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: passo 1, imagem 2 %32 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Volume and Screen Buttons: passo 1, imagem 3 %32
    • Locate the four 3.5 mm Phillips screws holding the silver back plate and the screen together. There are two screws on the top and two screws on the bottom.
    • Using the Phillips #00 Screwdriver, remove all four screws.
    • ● Remove the screws with the least amount of force possible to avoid damage to the threads. If thread damage occurs, screw removal will become more difficult.
  2. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: passo 2, imagem 1 %32 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: passo 2, imagem 2 %32 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement: passo 2, imagem 3 %32
    • Flip your device so that the long side without the buttons faces you.
    • Insert the Plastic Opening Tool between the silver back plate and the screen about one inch from the corner of the device on either side.
    • Using the Plastic Opening Tool, pry open the screen until it unsnaps from the back plate.
    • Work your way down the edge of the device, unsnapping all locations where the screen meets the silver back plate.
    • Go around the corners with the Plastic Opening Tool and unsnap additional snap-in locations as necessary.
    • Once the screen is loose, pull it towards you, then lift it to prevent damage to the buttons on the other side of the device.
  3. Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: passo 3, imagem 1 %32 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: passo 3, imagem 2 %32 Digitac Jazz Ultratab C725 Volume and Screen Buttons Replacement, Freeing the buttons: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, poke the square plastic piece between each of the buttons that connect them together. Each button has a plastic piece between their gaps.
    • While poking the square piece in, simultaneously push it upward to release it.
    • After releasing the first one, use the pair of tweezers, and do the same with the second one. This should free all buttons from the device.
    • Once the buttons are free, use the set of tweezers to grab the buttons and pull them out.
Conclusão
Seth York
Membro desde: 01/20/15
355 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-6, Blackwell Winter 2015 Membro de USF Tampa, Team 11-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G6
2 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 385
