Ir para o conteúdo principal
Digitac Jazz Ultratab C725 Charging Port Replacement
O que você precisa
  1. Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: passo 1, imagem 2 %32 Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: passo 1, imagem 3 %32
    • Locate the four 3.5 mm Phillips head screws holding the silver back plate and the screen together. There are 2 screws on the top and another 2 screws on the bottom.
    • Remove all four screws with the Phillips #00 screwdriver.
    • Remove the screws with the least amount of force. The removal of the screw will be more difficult if thread damage occurs.
  2. Digitac Jazz Ultratab C725 Charging Port Replacement: passo 2, imagem 1 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 2, imagem 2 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 2, imagem 3 %32
    • Flip your device so that the long side without the buttons is facing you.
    • Insert the plastic opening tool between the silver back plate and the screen. From the corner of the device on either side, pry the seam of the device about 1 inch.
    • With the plastic opening tool, pry the screen apart from the back plate.
    • Keep prying the screen apart from the back plate until they are separated.
    • With the plastic opening tool, if necessary, pry apart the remaining seams of the device.
    • After the screen is loose, pull the screen towards you. Lift it to prevent damage to the buttons.
  3. Digitac Jazz Ultratab C725 Charging Port Replacement: passo 3, imagem 1 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 3, imagem 2 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 3, imagem 3 %32
    • Locate the 3 black clips on the motherboard that hold the data cables./
    • Using the Spudger, pry the black clips up to a 90 degree angle./
    • Pull the data cables out once the clips are up to a 90 degree angle.
    • Repeat this for all 3 clips.
  4. Digitac Jazz Ultratab C725 Charging Port Replacement: passo 4, imagem 1 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 4, imagem 2 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 4, imagem 3 %32
    • Locate the two 4.0 mm Phillips head screws that are holding the motherboard in place.
    • Use the Phillips #00 screwdriver to remove both of the screws.
  5. Digitac Jazz Ultratab C725 Charging Port Replacement: passo 5, imagem 1 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 5, imagem 2 %32 Digitac Jazz Ultratab C725 Charging Port Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • The motherboard should now be loose.
    • To gain access to the charging port, flip the motherboard over.
    • Use the tweezers to pull the charging port off of the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 11-6, Blackwell Winter 2015 Membro de USF Tampa, Team 11-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G6
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 472
