Ir para o conteúdo principal
Digiland 10.1'' DL1016 Screen Replacement
O que você precisa
  1. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: passo 1, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: passo 1, imagem 2 %32
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Screen Replacement: passo 2, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement: passo 2, imagem 2 %32
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: passo 3, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: passo 3, imagem 2 %32
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: passo 4, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: passo 4, imagem 2 %32
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Screen Replacement, Power Button: passo 5, imagem 1 %32
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Screen Replacement: passo 6, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement: passo 6, imagem 2 %32
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Screen Replacement, Screen: passo 7, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement, Screen: passo 7, imagem 2 %32
    • Remove the tape from the backside of the tablet along with the wiring.
    • Make space so you can pry the motherboard away from the digitizer.
  8. Digiland 10.1'' DL1016 Screen Replacement: passo 8, imagem 1 %32 Digiland 10.1'' DL1016 Screen Replacement: passo 8, imagem 2 %32
    • Once the motherboard is pulled away, the screen should be free of all other components.
    • Check around the edges so that no tape is stuck to the edges or wiring and just push off digitizer and replace screen if needed.
Conclusão
Virginia Tapia
Membro desde: 08/26/19
386 Reputação
3 Guias de autoria
Equipe
Gateway, Team S1-G2, Saknee Fall 2019 Membro de Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 Membros
5 Guias de autoria
3 comentários
Where can i get the screen for this tablet? i need to order online and currently i am in india.
Arivu Alagan - Responder
Where will I get screen in kenya
Josphat Mutai - Responder
My phone crack,I need screen only
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 1,607
