Ir para o conteúdo principal
Digiland 10.1'' DL1016 Battery Replacement
O que você precisa
  1. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Backing: passo 1, imagem 1 %32 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Backing: passo 1, imagem 2 %32
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Battery Replacement: passo 2, imagem 1 %32 Digiland 10.1'' DL1016 Battery Replacement: passo 2, imagem 2 %32
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: passo 3, imagem 1 %32 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: passo 3, imagem 2 %32 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: passo 3, imagem 3 %32
    • Pull back the black flaps on the ZIF cable connectors.
    • Pull the ribbon cables out of the connectors.
  4. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Battery: passo 4, imagem 1 %32 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Battery: passo 4, imagem 2 %32
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Once you remove the battery, simply replace the battery with a new one.
Conclusão
Virginia Tapia
Membro desde: 08/26/19
386 Reputação
3 Guias de autoria
Equipe
Gateway, Team S1-G2, Saknee Fall 2019 Membro de Gateway, Team S1-G2, Saknee Fall 2019
GCC-SAKNEE-F19S1G2
4 Membros
5 Guias de autoria
Um comentário
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
Sergii Prokhorov - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 1,859
