Ir para o conteúdo principal
DigiTech RP70 Motherboard Replacement
O que você precisa
  1. DigiTech RP70 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 DigiTech RP70 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Motherboard Replacement: passo 2, imagem 1 %32 DigiTech RP70 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
My digitech rp 80 not work. How to get new motherboard
Thadevus - Responder
My digitecj rp 80 not working. No display no sound how to get new motherboard
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 899
