Ir para o conteúdo principal
DigiLand DL801W Power and Volume Button Assembly Replacement
O que você precisa
  1. DigiLand DL801W Power and Volume Button Assembly Replacement, Power and Volume Button Assembly: passo 1, imagem 1 %32
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Power and Volume Button Assembly Replacement: passo 2, imagem 1 %32
    • Remove the 10 JIS #000 screws from the back of the device.
  3. DigiLand DL801W Power and Volume Button Assembly Replacement: passo 3, imagem 1 %32 DigiLand DL801W Power and Volume Button Assembly Replacement: passo 3, imagem 2 %32 DigiLand DL801W Power and Volume Button Assembly Replacement: passo 3, imagem 3 %32
    • Using a spudger, lift the flaps securing the four ZIF connectors.
    • The smaller of the four flaps may require you to use the point end of the spudger.
    • Use the pointed end of the spudger to disconnect the ribbon cables from their ZIF connectors.
    • Be careful not to damage any of the wires. If damaged, the tablet may not work correctly after repairing.
  4. DigiLand DL801W Power and Volume Button Assembly Replacement: passo 4, imagem 1 %32
    • After removing all of the screws and disconnect any wires, use the blue plastic opening tool and starting from the bottom near the battery, carefully lift the back metal plate and motherboard out. Set aside in a secure place.
  5. DigiLand DL801W Power and Volume Button Assembly Replacement: passo 5, imagem 1 %32 DigiLand DL801W Power and Volume Button Assembly Replacement: passo 5, imagem 2 %32
    • Disconnect battery terminal using the black spudger.
    • Once the battery is disconnected, the motherboard should lift right off of the metal back plate.
    • Now you will be able to remove the Power Button and Volume Assembly with a soldering iron.
Conclusão
Travis Mangum
Membro desde: 09/17/15
572 Reputação
4 Guias de autoria
Equipe
IUPUI, Team 3-4, Harley Fall 2015 Membro de IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Membros
10 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,541
