Ir para o conteúdo principal
DigiLand DL801W Microphone Replacement
O que você precisa
  1. DigiLand DL801W Microphone Replacement, Microphone: passo 1, imagem 1 %32
    • Please be aware that removing the back panel from the tablet could cause damage to the back or front panel.
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Microphone Replacement: passo 2, imagem 1 %32
    • Using the black spudger, insert the point underneath the red and black wires. Gently lift the microphone out of its socket.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective microphone.
    • If you have removed the microphone and cannot remember which wire went where, don't worry. The wire terminals on the motherboard are marked with a " + " and " - " sign.
Conclusão
Uma outra pessoa concluiu este guia.
Travis Mangum
Membro desde: 09/17/15
572 Reputação
4 Guias de autoria
Equipe
IUPUI, Team 3-4, Harley Fall 2015 Membro de IUPUI, Team 3-4, Harley Fall 2015
IUPUI-HARLEY-F15S3G4
4 Membros
10 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 310
