O que você precisa
Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
Using the black spudger, insert the flat edge between the battery and the metal plate. Continue until the battery is completely separated from the metal plate.
Once the battery is separated from the metal plate, it is safe to detach the wires from the motherboard.
4 outras pessoas executaram este guia.
2 comentários
all you have to do to open this tablet is put a very small flat head screwdriver in the headphone jack and turn it. the top and bottom plastic covers will separate. you don’t need any special tools.
