Ir para o conteúdo principal
DigiLand DL8006 Speaker Replacement
O que você precisa
  1. DigiLand DL8006 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: passo 2, imagem 1 %32 DigiLand DL8006 Speaker Replacement: passo 2, imagem 2 %32
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: passo 3, imagem 1 %32 DigiLand DL8006 Speaker Replacement: passo 3, imagem 2 %32
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: passo 4, imagem 1 %32 DigiLand DL8006 Speaker Replacement: passo 4, imagem 2 %32 DigiLand DL8006 Speaker Replacement: passo 4, imagem 3 %32
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: passo 5, imagem 1 %32
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: passo 6, imagem 1 %32 DigiLand DL8006 Speaker Replacement: passo 6, imagem 2 %32
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 118
