Ir para o conteúdo principal
DigiLand DL8006 Motherboard Replacement
O que você precisa
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 DigiLand DL8006 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
  2. DigiLand DL8006 Motherboard Replacement: passo 2, imagem 1 %32
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
  3. DigiLand DL8006 Motherboard Replacement: passo 3, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 3, imagem 2 %32 DigiLand DL8006 Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
  4. DigiLand DL8006 Motherboard Replacement: passo 4, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 4, imagem 2 %32
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
  5. DigiLand DL8006 Motherboard Replacement: passo 5, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 5, imagem 2 %32
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
  6. DigiLand DL8006 Motherboard Replacement: passo 6, imagem 1 %32 DigiLand DL8006 Motherboard Replacement: passo 6, imagem 2 %32 DigiLand DL8006 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
  7. DigiLand DL8006 Motherboard Replacement: passo 7, imagem 1 %32
    • Gently remove the motherboard from the case.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 144
