Ir para o conteúdo principal
DigiLand DL8006 Internal Ribbon Replacement
O que você precisa
  1. DigiLand DL8006 Internal Ribbon Replacement, Internal Ribbon: passo 1, imagem 1 %32 DigiLand DL8006 Internal Ribbon Replacement, Internal Ribbon: passo 1, imagem 2 %32 DigiLand DL8006 Internal Ribbon Replacement, Internal Ribbon: passo 1, imagem 3 %32
    • Flip the tablet to where its back is facing upward.
    • Remove the back cover by prying the sides with a plastic opening tool.
    • Lay the opened device with the circuit board exposed.
  2. DigiLand DL8006 Internal Ribbon Replacement: passo 2, imagem 1 %32 DigiLand DL8006 Internal Ribbon Replacement: passo 2, imagem 2 %32
    • Remove the silver/metallic tape covering the blue and red wires overlapping the upper and lower end of the ribbon cable.
  3. DigiLand DL8006 Internal Ribbon Replacement: passo 3, imagem 1 %32 DigiLand DL8006 Internal Ribbon Replacement: passo 3, imagem 2 %32 DigiLand DL8006 Internal Ribbon Replacement: passo 3, imagem 3 %32
    • Remove the ribbon cable by pulling the locking tab of the ZIF connector up and pulling the ribbon cable out with tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 113
