Ir para o conteúdo principal
DigiLand DL718M Speaker Replacement
O que você precisa
  1. DigiLand DL718M Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove back panel by wedging the iFixit opening tool on all four sides of the device.
  2. DigiLand DL718M Speaker Replacement, Speaker: passo 2, imagem 1 %32
    • Lift the speaker from the top right corner of the device using an opening tool.
    • The speaker should come off easily. If it does not, look for any tape or adhesive that may be fastening it to the internal panel of the device, and remove it.
  3. DigiLand DL718M Speaker Replacement: passo 3, imagem 1 %32 DigiLand DL718M Speaker Replacement: passo 3, imagem 2 %32
    • Desolder the two wires from the motherboard that connect to the speaker.
    • Remove the speaker from the tablet.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 94
